U-Joint
1982 bronco lifter
angelica N.Y
my bronco had no four wheel drive in it when i bought it we discovered it needed U-Joints and i was wondering how you could get an old rusted U-Joint out.
Yardape
Alberta
Big hammer and socket, Soak ut down with penetrating oil, find a socket that the u-joint cap will fit into, put that one on the groundfind one the same size as the cap, or a tiny bit smaller. Put that one one top of the cap and pound on it with your hammer.
1982 bronco lifter
angelica N.Y
i also should of told you it is the transfer case where there is like a bump in the thing and you cant get it off unless you take the top bracket off and thats what i need help with my bad
Yardape
Alberta
What are you talking about? Now I have no idea what you mean
1982 bronco lifter
angelica N.Y
where the drive shaft comes off the transfer case to the front axel and on the transfer case there is where the U-joints mount there are two bumps on it that make so you cant
The driveshaft is secured to the transfer case yoke with u-BOLTS. There is a nut on each end of the u-bolt. Undo the nuts, and release the u-bolts to remvoe the driveshaft with u-joints. If you can't see this, clean everything off, as it's probably covered with gunk.
Yardape
Alberta
I think I have an idea what hes talking about. I stripped a '95 F-150 4x4, And the u-joint ubolts were seized in the holes of the yoke up by the transfercase. Thats the only thing I can think of that he could talking about. In that case, soak the crap out of it with WD-40 and try and tap them in with a hammer, the put a prybar between the u-joint and the yoke and try and pry it out square. Will take some elbow grease but is possible. If it only comes out a little ways, tap it in and pry out again, Might take a few times but will work. watch your eyes because alot of rust powder will come out with it. Before you re-install take a drill bit close to the same size as the hole and work it in and out to remove all rust and dirt. (do this by hand)
eholt80
