Twin-sticks
nothingfancy68
I'm new to the 4x4 world. I'm finishing up with a modification job on a 68. I have added Duff's Twin-Sticks to the Dana 20. Should I be able to engage just the front axle in either high or low and leave the rear in neutral? The Duff's sales guy on the phone said yes, the local guy at the transmission shop who rebuilt the Dana says no. Please help!
"Nothing Fancy" home page
STLKIKN
Calgary Alberta
I built my own twin stick for my D20... I have hi, neutral and low independantly front or rear.
I would assume that the Duff kit should do the same.
S_bolt19
Colorado
I would like to see your twin stick. Is it tough to build? I wouldn't mind going w/it but I dont have the time to figure it out currently so if you got a drawing or something, I would like to see it.
N
nothingfancy68
Thanks, My "rebuilt" Dana must have some serious issues. The stick for the front will only follow what the rear is doing. If I put the rear in high the front will go into high, same for low. The problem is that when the rear is in nuetral the front will not go into gear. The guy who rebuilt it said there are not enough gears in there for all that. All I should be able to get are 2L, 2H (rear wheel drive only), 4L & 4H. It looks like I'll be pulling it back out.
STLKIKN
Calgary Alberta
S bolt, no it was actually very simple.
I used a shifters from D 20 and D 300 J**ps.
At the moment it looks kind of ghetto fab, but it isn't currently in the truck.
I will try and get a pic or two of it mounted on one of my spare cases
and post them. I must mention though that this one is a 77 D 20.
S_bolt19
Colorado
Ahh, the J-shifter, I got the T-shifter....Do you know if the T can do the twin stick conversion? I have heard that it can but I dont know if it will work.
STLKIKN
Calgary Alberta
S bolt, nothin fancy posted a pic in the other post showing the shifters installed on the trans/ t/case assy.... looks like it would be fairly simple to re create...
upnorth
Kodiak, AK
Nothingfancy68,
There is an indent between the rails of the shifter of at least earlier Dana 20's that won't allow the rails to be moved out of sequence. There is nothing wrong with your transfer case, all that is needed is to go back into the case and do a little cutting/grinding. It's strange that the Duff guy should say it should. Your local guy is right though.
bajaplayboy
to rock crawl meaning use only the front or only the rear axle means you have to go in to the xfer case adn remove the detents. Then it should work. The kit I dont know about. but the detent balls are what keep them moving together.
jfarish
Orem,UT
If you look under twin stick title I did on classicbroncos.com they will help you outa lot they helped me turn my j-shift into a twinstick amd they have good pics too I hope that will help
jarrod
Similar threads
T
Replies
Views
2K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
831
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
figjeti
