its positively play only....im also doing the solid axle swap once its runing....dana 60 all around.....i just need to know what else i will NEED to efficiently run this engine at a 418......i did some research and found that the block alone is way beefier than a 302 and that it will gladly take on the 418.....kits go up to a rarely seen 454.....but a more common 427 stroker kit....like i said though.....once i buy the kit....crank, connecting rods, pistons, bearings.......what else will i need?
yes the kits go up to 454, but to build this size small block you have to use an aftermarket block. I have built the 454/460 version with a svo sportsman block some time ago and if I am not mistakin at 427 you even have to go aftermarket block, not sure of the 418, but I am confident that the 9 extra cubic inches are in the bore.
Just in case anyone wants the formula for figuring out cubic inches on a V8 it is simple Bore X Bore X Stroke X 6.283
on any other motor keep BxBxSxNumber of Cylindersx.7854
IMO if you are building a true play truck the easiest stroker would be a 460 with a 400 crank ground to accept Chevy rods thus producing 523 cubic inches. This stroker is an easy one to do and has more torque than you will ever need. In fact with this stroker all you need is a competent machine shop to do the grinding of the crank, and if you wanted to you could even go the align boring route and add aftermarket splayed 4 bolt main caps, but this really isn't neccessary.
Now if you happened upon a factory Boss 429 Block (all five main caps are four bolts) this could be punched up to around 598 cubic inches.
Stay away from the 460 stroker using 300 6 cylinder rods as I have seen these emplode once too often
I was combing thru my notes after writing this I think a stock 351 W Block will only accept a 6.00 inch rod length thus giving a a max stroke of 4.00 or in otherwords a max displacement of 402 with a stock bore.
