Tires on 77 Bronco
montywynn
What is the largest tire to fit on a 77 bronco (stock/no lift) without any rubbing? Thanks in advance.
Hey Monty, Welcome.
The standard tire is a 235/75/15 that is about 29 inches tall. What, if any, size larger that will fit without rubbing anything depends on other factors, such as rim width, tread width, and section width.
If you are buying from a tire dealer, they will usually be willing to mount 1 tire and allow you to see that there are no clearance issues.
Good Luck
sandman90
Laurel,DE
Hey Monty, I have a 76 with no lift and I run 31x10.50s on 8in rims. I did have to cut the front corners off from the inside of the front fenders for clearance. You can't even tell it looking at it,but I have flares on the rear,I'm not sure if that will give you any problems or not.
Staff online
stevedave
