1990 Ford bronco
ok so i cut the wires and connected voltage in bothe directions across the motor... so i can hear the motor struggling in both up and down directions, but the window doesnt budge. I used some elbow grease and managed to budge the window down an inch and then i put it back up after i was done screwing around for the night. The big semicircle gears are rusted a little and have almost no lubrication.. i will go swipe some lithium greese this weekend and **** them up but im wondering if maybe the gears inside the motor are stripped. I have an identical motor that i snatched from the junk yard last weekend and the teeth that are exposed look fine.
OK SO.. how the **** do i replace the motor? true -there are only three small bolts holding the motor, but its a bitch to reach while ur inside the care and even if i am able to het the old motor out, i dont think i will be able to get the new motor in. is there any way to put the motor in from the outside of the truck? andi dont meant cutting a hole in the tale gate with snips. I think the tail gate may be one big piece of sheet metal and there may not be any other way to get to the motor other than from the inside... ok like i said. I can probably get the old motor out but i have a feeling i will not be able to get the new one in... not enough space and i gotta worry about lining up the teeth..maybey lubing the gears is all i need.. hmm anyone know about changeing that motor out easily? can it be done from outside the truck?
