2 days ago my rear window switch and my drivers side passenger window switch stopped working, I know it isn't the motors because the rear window still works with the key and the passenger window still rolls down when I use the passenger side switch. The divers side passenger window switch will work when it is cold outside though 50 or lower?
I went ahead and took of the door pannels and the wiring seemed to be fine and I would normally assume its the switches but because they both went out together I figured I should check here first.
Thanks
Kyle
Thanks
Kyle
