Sway Bar
michibronc
Flint, MI
I've heard that you can get rid of the front sway bar on the TTB with few adverse effects, but then again I don't have any advice that comes from first hand experience, just a website's advice. Has anyone heard of this or had experience with it?
I only have one on the back and it handles just fine. Without the one on the back I get too much roll. The easiest thing to do is disconnect it from the front and see how you like the handling. It can be disconnected and removed in less than 1/2 hour and the same to reinstall it if necessary.
michibronc
michibronc
Flint, MI
Good advice - one more question before I quit bugging you - did your year bronco have a front bar stock?
It was an option. Nothing is different with the front end with or without it. Springs and shocks are the same.
89Bronco58
Jersey
my truck has front and rear swaybars, i removed both and it doesnt roll hardly at all, i do have a 6 inch susp lift but i have bigger and thicker front coild, arched rear springs w/ add a leaf, and tought skyjacker shocks, so im sure that helps, i wouldnt remove them on a bronco with stock suspension without doing a suspension upgrade, or at least stiffer shocks, just my opionion
