suspension setup
1fast
there are a ton of threads on this and upon alot of research i think i have decided on the best setup for the money tell me if i am wrong or not
1.2 inch body lift
2. superlift 4 inch lift springs
3. 2 inch blocks for the rear
4. 4 4 inch lift shocks
i think this should make for a level truck and only cost about 370 bucks
thornbirdguy
Jamesville, NC
1.2 inch body lift
the susp. lift should be plenty. what size rims and what backspacing?
On your Bronco, 1fast, i would just cut the fender openings. But if you want to lift the Bronco with springs, you will need to get a full kit for the suspension lift in either a 4" or 6". The alignment and tracking of your front TTB axle (Twin Traction Beam) will not work if you just install taller coils, The kit contains the coils, longer shocks, a dropped Pitman arm for your steering linkage, and drop brackets for the axle beams and radius arms. Here's a link to my lift kit gallery with a Skyjacker 6" kit, longer radius arms and lifted rear springs:
http://www.supermotors.net/clubs/superford...stry/1133/29624
I don't like body lifts, as I feel they're unsafe and they don't improve your suspension travel. But a 2" body lift and some minor trimming will fit those 35's better than they are now.
1fast
yea i think i have decided against the body lift and just gonnaa cut and get a 4 or 6 inch suspension lift kit with everything i need seems easier than piecing a kit together it will be a while though before i can spend the money on it though hopng by the end of the month who knows
Coastersfwb
