Stupid Wiring Question
Don73
Stupid question - I just replaced the battery and found the negative terminal on the new battery too far away for the existing cable. It was a shorter drive to Autozone than to Sears so I just bought a longer cable. When replacing I found a braided wire grounded along with the battery cable, but it isn't connected to anything. Should it be?
Thanks for any help,
Don
If it's a small braded wire, it is usually attached to the body to provide a ground for lights, etc. Normally there is a large cable from the battery to the engine block and a small one from an intake manafold bolt to the firewall. The large one is to provide a high current ground for the starter. The small one continues the grounding to the body to make sure you get a good ground there.
Broncoholics
Broncoholics
Washington State
I remember having the same flat ground cable disconnected from the body. The bolt had fallen out of the firewall side but was still connected to the engine. I reconnected it and the engine seemed to run better... :blink: I went to my buddies house where his engine has always had a misfire. We added a ground strap (body to engine) and it now runs great. So I am now a firm beliver in good grounds. b-(
stevedave
