stock steering column
73dreambronco
when I removed the shaft(that the steering wheel bolts to) from the column I noticed a rubber bushing that was almost completely destroyed(far end of column opposite steering wheel ) when I looked at the parts diagram I noticed there was a rubber bushing and a bearing set in the far end of the Column. I could not locate any bearing. its a 73 with power steering. does anyone know what I need to rebuild this end of the column. Ill post pics if need be.
thanks
Sandoval_broncosauria
