steering woes
broncodriver33
Palmyra, Pa
just installed 2.5" lift kit on 93 bronco. and now when i turn one way and go to turn the opposite my steering gets real stiff. do i need a drop pitman arm. my power steering fluid and joints are all ok. if i do need a drop pitman arm does anyone know where i can get one for a 2.5" lift. or is something else causing this problem? please help
I would say yes, as most lift kits come with a dropped Pitman arm. But I would suggest watching the steering linkage while someone turns the wheel lock to lock, and watch for any binding or slack. Did you have the alignment checked after the lift?
Coastersfwb
