BRONCOTUFF
HELLO.... WORKING ON MY 77 BRONCO. IT DOES NOT COME OUT OF PARK BY USING THE SHIFTER ON THE COLUMN. FIGURED IT WAS THE SHIFT TUBE THAT GIVE OUT. STARTING TO TEAR OUT THE STEERING COLUMN. WIRE HARNESS CONNECTION IS PULLED APART. MOUNTING BOLTS ARE LOOSE AND READY TO TAKE OUT. MY BIGGEST PROBLEM IS GETTING THE LINKAGE THAT COMES UP FROM THE TRANSMISSION TO THE END OF THE STEERING COLUMN POPPED OFF THERE.... I DON'T KNOW IF THERE IS A TRICK OR A SECRET ????? ANY SUGGESTIONS OR HELP WOULD BE GREAT !!!!! THANKS IN ADVANCE........
