Spindle
BlueThunder
How the **** do you get the spindles off? The books say gently but there not moving the least bit....
89Bronco58
Jersey
im assuming you have everything off and are down to the spindle itself, did you remove the 5 nuts that hold it to the steering nuckle? if so i would hit it with a RUBBER mallet, thats how mine came off, easy as anything could have been
BlueThunder
BlueThunder
Well rubber mallet = no success...same with a regular hammer...and same goes for the sledge hammer....and same goes for it heat up and the sledge hammer...they are %&$*in' stuck! and yes the 5 nuts are off...
ricks73eb
little chute wi
well if your at your wits end take it out on the caliper mounts thats mite loosin them um..lol i got a early bronco front end im havin the same problem with.. worst case and iv done it b4.... tape a short (6 to 8 inch piece) 2X4 to the spindle and beat it like a it scratched your favorite cd!!!
goodluck!! btw hose everything down with pb blaster or whatever u use to loosen bolts and let it sit for a day or so..
freak
Indiana
I used a 4x4 piece of wood and a 12lb sledge. That worked, just don't miss.
BlueThunder
BlueThunder
ok so after beating the ever living $*#$#%(#@*%* out of it. It finally came off. atleast the drivers side....next to come is the passengers side....i found that also using a puller and pulling against the drive shaft helped or atleast aided a little bit...
figjeti
