Sorry another vacuum line ?
mack1013
Greenville SC
Hello all, I am new here and have been looking through the forums for a copy of the vacuum diagram on the radiator support for a 1989 fsb 351w? I looked at all the links not very helpful in my situation. i just completed a valve job and headers etc. and got everything put back and half of my labels on the lines where gone or smeared? 9A couple to many beers on disassembly) Any help would be grateful so I can get my beast on the trails again! Also looking for a softtop? Thanx Scott
I don't have as diagram, but here is a list of where to run lines from the main vacuum tree.
3/8" line from center post to the Power breaks
1/4" line to MAP
3/16" line to fuel regulator
3/16" line to EGR
5/16" line to Speed Control
1/4" line to Automatic Transmission, (except E40OD)
T off or directly to check valve for A/C, (the valve could be built into the vacuum reservoir),
from the reservoir to the A/C controls
M
mack1013
Greenville SC
Thank you seabronc, That helps me out alot! I just got done rebuilding the motor and did a test fire last night it was rough to start and blew alot of black smoke? I checked most of the injector lines and hoses but it got dark. It really sucks I have alot of time and money invested in this build. But anyway I appreciate the info and if you have any outside opinions on my current ordeal would welcomed also?
yo!
and try this to add what our pal Seabronc advised;
<a href="http://www.motorcraftservice.com/vdirs/retail/default.asp?pageid=&gutsid=" target="_blank">88 & UP; Vehicle Emission Control Information (VECI), PUK (49 States) Decal, PGP (Canada) Decal, partial Vacuum Diagrams & Calibration Parts List for 88 & UP On-Line at Ford (Click "Quick Guides" in left panel, Scroll to: "VECI labels are now accessible through Quick Guides without a subscription." Enter applicable info (need to know your Calibration number off of your PCM) - located @ Drivers side kick panel
Source: by Ford motorcraftservice.com </a>
eholt80
