soft top plastic windows
bigbluebronc
ca
What is the best plastic window polish and procedure. I used a little carnuba and it helped a little but what is the best juice and procedure! Thanks
Probably the best thing to use on plastic windows, light lenses, etc. is a high grade Plexiglas polish which is available at some auto supplies but definitely available from a Fixed Base Operator at most small airports.
bigbluebronc
bigbluebronc
ca
Thank you, I run the soft top in the winter and with out a clear window I find my self getting close too "bumping" other autos and trees and such..
Thanks any application methods ? Wheel, hand, drill??? For maximum speed and polish?
Thank you, I run the soft top in the winter and with out a clear window I find my self getting close too "bumping" other autos and trees and such..Thanks any application methods ? Wheel, hand, drill??? For maximum speed and polish?
You apply by hand only.
