shift to the floor
broncostuff
I have a 68 with a 302 and 3 on the tree, Id like to switch to a floor shifter, has anybody that has done this have any feed back as to any problems youve run into also what brand shifter did you use, pro's and con
thank you
Bronc76
I have a 68 with a 302 and 3 on the tree, Id like to switch to a floor shifter, has anybody that has done this have any feed back as to any problems youve run into also what brand shifter did you use, pro's and conthank you
Check out JBG or james duff. they should have everything you need to convert to floor without any problems
Where are you..? Left coast is Toms & Wild horses
Pretty easy 1 banana job... just follow the directions. You'll be glad you did it...!!
I've had both Duffs & Hurst...they both work fine.
S_bolt19
Colorado
I think that Hurst might possibly make the Duff shifters...ever lay them side by side? They are almost identical. The parts can interchange. What ever you do, don't get the speed shifter or you will be locking the shift rails up all the time. Ask me how I know that one :rolleyes:
scrub
Ponoka, AB
Running the Hurst in my 76. Works well. Only beefs- When putting into park u can break a piece of the front housing out in ya slam it to hard. (It's only plastic) Shift pattern can get kinda annoying if shifting from D to R a lot.
"How is the 200 I6 with the 250 head for power? "
I think that question is directed at me.....
I've had 6 EB's & this is the one I kept., if that tells ya anything.. ^_^ /emoticons/[email protected] 2x" width="20" height="20" />
Flys down the frwy. & always the rig folks try to out do out in the dirt.
However., headers & 456's, I'm sure, come into play as well.
S_bolt19
Colorado
I woudn't balk at taking a 6-banger. Better gas mileage than the V8 and they are bullet proof. You don't have the snap your head acceleration, but why would you want it in an EB...you get the snap your head torque though ;) /emoticons/[email protected] 2x" width="20" height="20" />
kyleh01
