set front doors
jats
Took my 74 apart for paint now the drivers door has a gap at the rear it closes, but when you are inside you can see daylight where the new door seals are it needs to come back about a quarter of an inch. Any ideas, on how to move door back or to move the latch so the door will close further.
S_bolt19
Colorado
the hing mounting plates in the pillar will move up, down, in & out. You also need to loosten up the door latch on the rear pillar. They are a royal pain in the rear to adjust, it might be worth the money to just take it to a body shop and let them do it if you can get it done for a C-note.
J
jats
Thanks for the info I have screwed with is long enough, Iam going to take your advise.....
Sandoval_broncosauria
