Rubbing problems with the ttb
Billings Lee
Billings Lee
Portland, Oregon
Im having rubbing issues with my ttb axle check this out and what should i do.
and yes i know a axle swap would solve my problems.
Cant you cut that area out? Looks like you have a 4 inch lift so more "customizing" is necessary.
92broncobeast
Shepherdsville, Ky
good chioce you could start a frackture or other (worse) issues i would not try cutting check all busshings and mounts brackets anything that could be wornout or bent i had one do that and it was a bad bushing. last resort would be to use a grinder and shave a little bit off of there dont cut but grind it off smothe and strait. good luck and let use know how it goes
Coastersfwb
