rims?????
dsgb9840
atlanta ga
ok so i work a discount tire, and am about to lift my 94 bronco 6". i wanted to put 35 12x50 18. ok so the problem i having is i have spent days at work looking for rims i liked and wold fit my bronco.......none. the biggest problem im having is the center bore. it's 110mm and there are few rims that have it that big. so now i sit on my lift, stuck with no where to go any one know of a black 18" that fits? or should i just say ***** it and change the bolt pattern cuz a lot of the rims for a f250 or f350 will fit?
Burns
Royersford, PA
I'm not sure exactly what they have, but I've seen a lot of lifted trucks on American Racing rims. They have almost, if not every, bolt pattern rim out there and an insane selection. I'd give them a shot and see if they have anything you like.
They're also the rims I have, black rock crawler solid steel ones. They're about twice as heavy as my old Ford rims and about a hundred times stronger and durable.
firelt90bronco
Ask me about my job
northeast
I like my 15" American racing tailgunners on my 33s. 18s might be too big and flashy for a lifted truck.
There was a Bronc ofor sale on ebay a month or so back, had some 18" CenterLine rims for the 4" front hubs. The F250/F350 wheels prolly won't work ,since they're 8x6-1/4" vs the Bronco 5x5-1/2". No adapters are available for the increased lug bolt pattern from 5-1/2" to 6-1/4". You might check with Bart Monster wheels, I have seen a couple of custom-made 16.5" 5-lug rims made by them for a Bronco. Most every 17/18" rim is for the 2WD or alter-model trucks, and even those are limited. JSM84
89Bronco58
Jersey
9 inch wide rims are too skinny for 12.50 wide tires. but many local autoparts stores actually have very very nice rims for 4wd trucks in stock or display , they can order you anything you need really, i priced a set of 18x12 polished beadlock rims, lets just say i could but a new motor with what they would cost me, but they are out there, dont limit yourself to looking online, call all autoparts stores and check :D /emoticons/[email protected] 2x" width="20" height="20" />
Coastersfwb
