rhino lining
ilystbronco
long island NY
i was thinking about rhino lining the bronco(95 fullsize)
on the spots were rust happens, but does it prevent rust? i was thinking of puting it like 5 inches all the way around on the bottom of the body and inside the fender well, is this a good idea and will it prevent rust and look good?
It will as long as it was prepped right, if moisture gets underneath then it will rust away. Rust Bullet is a great product, Check that out. I am going to do my body inside and out in rust bullet, then Durabak the whole thing inside and out.
I
ilystbronco
long island NY
i was thinkin of doing the whole back of the truck and the bottom of the body all the way around. what else should i do if i decide to line it? and is it alot of work to do?
I think you nedd to treat or remove the rusted areas before applying the bed liner.
boss
Yes rust bullet is great, treat with rust bullet and than cover with bed liner - heres my rust bullet liner project http://www.4x4preservation.com/forums/showthread.php?t=53
Broncosaurus!
Oshkosh WI
yeah they dont call it cancer fer nuthin, you need to get rid of all the rust or it will regenerate under whatever coating you put over it.
Coastersfwb
