Replacing solenoid on 1969 Bronco
olsonr
I recently replaced the solenoid on my 69 bronc and now i have no power when i turn the ignition? Is there something i did not do?
Hi olsonr, welcome.,
Wellllll., not real clear., why did you replace the old one.?
You said "recently replaced" Did the new one work for a while..?
Did you clean the attach point on the fender-well to make a good ground..?
Do you have a "volt-meter", or one of those little test lights..?
What does "no power" mean..? RU saying the gages don't cycle &/or when you turn the key, nothing happens..? :unsure:
O
olsonr
Wellllll., not real clear., why did you replace the old one.? i think ireplaced the original
You said "recently replaced" Did the new one work for a while..? no, just replaced today and no power
Did you clean the attach point on the fender-well to make a good ground..? yes
Do you have a "volt-meter", or one of those little test lights..? i will get one tomorrow
What does "no power" mean..? RU saying the gages don't cycle &/or when you turn the key, nothing happens..? :unsure: no power....
O
olsonr
Clean battery terminals and unfortunately still no power....
bigbluebronc
ca
I am guessing remote starter solinod is what you changed, check wiring, I dont know but could some universal stuff wire up different, or you have old wiring or connectors the might have broken within.
fred tyler
