Removing lower intake manifold.
BroncoDude00
91 Full size bronco, 5.8L engine. Could someone explain how to disconnect these connectors? I have the disconnect tool but I can not get them apart. Anyone? :(
Bebop Man
Rapid City, SD
91 Full size bronco, 5.8L engine. Could someone explain how to disconnect these connectors? I have the disconnect tool but I can not get them apart. Anyone? :( View attachment 9019
Pull off the safety clamp. Close the disconnect tool around the lip, then slide the tool into the lip. Grab the tool in one hand, the fuel line with the other, and they should pull apart.
There will probably be residual pressure in the line, so a rag or something to catch the fuel spray would be a good idea.
BroncoDude00
Yep, that is what I tried previously, neither the one on the going to the fuel regulator nor the one on the return line from the rail will come apart. Tried a little WD on both also, no luck. I will keep trying though, never give up.
Bebop Man
Rapid City, SD
On the female side (fuel rail) there is a circular metal spring that sits betweel the raised lip of the fuel line and the outside edge of the bulge of the fuel rail. That disconnect tool fits between the fuel line and the spring then spreads it wider so the lip of the fuel line can move past it.
BroncoDude00
Thanks Bebop, I found it in the Chiltons manual. I am thinking the disconnect tool I have is too thick, it is an OEM brand that I picked up at AutoZone and I noticed when I bought them they were thicker than the plain jane type tool. Proves more expensive is not always better. I can push the garter spring back on the return line connector but I don't think it is going far enough, the spring will sit there after I pull the tool out but the line will still not come apart. If I move the line around a little the spring pops back out. On the line to the regulator the tool will not fit into the opening. Going to run into NAPA when the wife gets home from work and get a different tool. Thanks for you help. :) /emoticons/[email protected] 2x" width="20" height="20" />
Sometimes the lines are very hard to pull apart, even using the correct-size tool. Be sure the tool goes all the way in the connector and fully disengages the spring. It may take several tries, but should come apart easily.
Yardape
Alberta
JSM has a good point, even when you think the tool is in far enough it still might need to go farther. With mine I inserted the tool then gave it a twist while pressing inward and it went in another 1/4 inch almost and the line popped apart
Staff online
kyleh01
