removing grill and light surrounds...
POTTER
Connecticut
There are bolts on top, but there seems to be another attachment point somewhere and I can't see to find it for some reason..any help?
That is a pain . On the bottom of the headlight there is the turnsignal . The outside retaining bolt I think it was for the turnsignal has a metal strap that hooks to that bolt then over to the core support . Spray oil on the bolt before you try to remove it though it is a very coarse stud and if the nuts stuck it will thread right out of the turnsignal . That should get the bezel loose and then you can get at the bolts that hold the turn signal in the bezel . :D /emoticons/[email protected] 2x" width="20" height="20" />
