kturner
if i add 35" tires to my 95 bronco with a 4' body lift will i have to regear?
what about adding 33's?
and what is the cost of regearing?
thanks
thanks
i would regear i put 4.56's in my bronco after putting on 35's and i noticed a big differenceif i add 35" tires to my 95 bronco with a 4' body lift will i have to regear?
thanks
What do i need for parts to re-gear, Is this difficult to do?a 351 on 35's will do just fine, it will be a little more sluggish than your used to but it will still drive good, i had a stock 302 and ran 38's before i did my gears, and it still spun the tires, once you regear youll love it, but for now you will be fine
i drove with 35 for like 2 years and it did fine i had 35 inch procomp and when i went muddin i went to a 36 inch tsl sx so nah youll be fine just weak powerSince I dont plan on re-gearing my truck anytime soon, should i not be considering 35's (does it make any difference that i have a 351). I would like to get them because they fill the gaps nicely on a 4" LIFT (and they look good). Would driving around with 35's on stock gears damage my truck?
you need gears that are higher than a 3.55 and youll need on for the front and the back and you will need to make them THE SAME dont think it will be better to have the front movein faster than the back if thet dont match they will tear out your transfer case and so on and yes it is hard and will take you a couple of days to do.... i had a trained professional with me when i didWhat do i need for parts to re-gear, Is this difficult to do?
how much did it cost?hahah the cost of regearing is high high high i just got done doin the same thing and man i took the easy way out i did it myself i put some 4.88 on and MaN do you feel like you got 100 more horse power i thoink it even helps on the gas ... i had 35 inch pro comp all terrieans and some tsls and compared to the stock 3.55 everytime i hit the gas it took forever to get up to speed even when i was in the mudd holes and just goosed it it took forever to get the responce but these 4.88 are kick A$$ ... i would deffinatly get someone who knows what they are doin if you ever try to do it yourself atleast get them to watch over you there is alot more to it than just buying the gear takin it apart and putting the new one in its alot of adjusting and perfecting believe me its worth it thought i started on friday and didnt get done till sunday afternoon and smeeled to high heaven but yeah deffiantly regear if your wanting to feel some horse power
I dont get it, what are you killing your gas mileage for then? A show truck?I'm dont 4 wheel often and for my use i don't need a whole lot of power for how i use the truck. So if take it easy and use my head i can add 35's without re-gearing?
