rear leafs
79bigbronco
Calgary, Alberta, Canada
What, if any differences are there between bronco leafs, & F150 leafs? Also , if you use F150 leafs do you have to move the rear bracket forward 1 1/2" when doing a shackle flip? :unsure:
RTM
17101[/snapback]
If the F150 is a 4X2 then the springs will be narrower than the 4X4 springs. All 4X4 springs are 3 inches wide and the non 4X4 springs will be 2.5 wide.
As for the shackle flip I have read that some move the brackets and some don't but it does appear the rear axle will change it's stock location by some amount. Using an F150 spring over a bronco spring will not help correct this.
fred tyler
