rear brake and signals dont work
Mudmagnet63
Geary Oklahoma ( go sooners )
1971 Bronco the front signals work but I have no rear signals or brake lights. The fuse to signals/brake was corroded so I pulled it out and cleaned it up a bit and front signals started working.after futher investigation I found that the brake light switch on the brake pedal is not hooked up the tabs for spades are broken off ( new one on order ). I have several wires that are hanging free under the dash and have ordered a color coded wiring diagram for the 71 bronco. Any clues on which wires go to the brake switch and to the tail lights. I also found a switch ( toggle ) under the dash that I assume went to the spare fuel tank? any ideas???
Bronc76
Look for a green wire for RH lights and y-bk for LH lights with brown being ground. The brake light switch has a red wire running to it with a r-bk wire running to turn signal switch.
I'm reading off a '73 diagram, this may or may not help.
M
Mudmagnet63
Thanks Bronc76 I havent had a chance to work on it yet.I have ordered front wheel bearings,warn hubs and new tie rod ends,lord knows what I'll find when I get in there. I'll trace down the wires you specfied. I hope to have my diagram by then which is specific for the 71
Thanks
Mud
69bronc347
southern michigan
check to make sure the connector is hooked up for the rear of the vehicleits located on the drivers side firewall between the wheel well and firewall
fred tyler
