Rain Gutters
colobronco
Littleton Co.
Just got a 1970 Bronco and the rain gutter in the front is leaking at the seam. What is the best fix for this?
Yellow 72
If its just a small leak it seems like you could just fill it up with caulk or "goop" or somethin like that.
Broncoholics
Broncoholics
Washington State
Use some JB Weld or even better Marine Tex which is like liquid metal and much stronger than JB weld but its hard to sand. It actually sparks when grinding on it. If you do a clean job while its wet you don't have to sand at all. You can find Marine tex at any Marine supply store, its used to patch fuel tanks! Good stuff!
Gary wilder
