Radiator Replacement
sandmann999
Abandoned Bronco
Moscow, ID
For the last several months, my temperature guage has been running at about 50% (straight up and down). I had it pressure tested and they told me that the flow through the radiator was bad.
I have it in my budget now to fix the radiator but was wondering what the best option is. Should I completely replace it? Or should I just have it cored out or something? What are some suggestions?
Secondly, does anyone know what type/style/model (whatever) of radiator I have? I have a 1981 with a 6 cyl 300. There's no A/C, and the radiator measures by about 28" wide, 21" tall, and 1.5" thick.
If I should replace it, where's the best place (price) to get a new one?
Thanks.
My personal preference is to replace it. You could be wasting your money on a boil out, it might work for a while and then just clog up again. You can get a heavy duty one from Auto Krafters http://www.autokrafters.com. The radiator without AC is number 557 ( 129.95) and the HD one is number 558 (134.95), radiator cap on the right side of the truck. Personally, I'd get the HD one and also consider adding a transmission oil cooler.
By the time you add shipping you can most likely get one from your local friendly auto parts store for the same price.
sandmann999
sandmann999
Abandoned Bronco
Moscow, ID
26314[/snapback]
Thanks for the info. Looks like my Bronco came with the Heavy Duty one stock. I'm waiting to hear back from Auto Krafters as the radiator didn't have a parts number with it (just the 558) so I'm not sure what shipping is. At $134.95 with shipping, it's probably still cheaper than anywhere around here, which I haven't found it for any less than $200.
tompa00
modesto, CA
i just replaced my radiator in my 93. i ordered mine from www.radiatorbarn.com there were pretty good as far as price (cheapest i found) and with helping me find what type of radiator i needed. try there and see what ya think.
sandmann999
sandmann999
Abandoned Bronco
Moscow, ID
26363[/snapback]
Wow, thanks a lot. That is definitely the best price I've ever seen. I ordered mine off of there.
eholt80
