CSM_Bronco
well guys....i finally got it running. remanufactured block and heads......bored .030 over.....stock cam for now.......HEI distributor (thats right HEI) edelbrock performer intake.....Barry Grant Speed Demon 650cfm vacumm secondary, electric choke. typing hurts i think i got arthritis........oh and headman full length headers 3" collector.....and a 2 1/2" dual, straight back, glasspack exhaust.......its sounds wicked guys....seriously....also got the air conditioning bypass pulley.....and i removed the smog pump.....got the bronco powered by Ford valve covers....edelbrock 9" air filter......and some minor ford red painting....it aint too bad.....i got a fuel pressure regulator on it at the moment....its sorta just rigged up to work for now.....can you blame me, its been 8 months since it hit the road last.....honestly it sounds bad ass....i'm so damn happy right now....i'm surprised i have the patience to sit down here and type all this......i currently however do not have the tach, oil pressure, or water temp gauges hooked up......the wireing is all jacked up from the mpfi to carb swap......but on the other hand....in a day or two, a temporary 3 gauge cluster is going on to solve that problem.....so with that being said....................pictures will come soon.....hopefully a video to go along.....i'll write soon.....til then, hope you like it.
jake
jake
