power/drive train swap question
necessayrevil
right now i have a 86 bronco xlt with the stock 351w 4bbl c4 trans and an unknown t-case with 9in rearend. i work at a local wrecking yard so part are plentiful and cheap, i have a 460 with a c6 and a np208 t-case out of a 78 f-250 and i was thinking about droping it in my rig iv been asking around about it and ive been getting every kind of answer about what it would take to make it work, and im hoping you guys could settle this for me.
Bebop Man
Rapid City, SD
All you'll need is new motor mounts. Driveshafts will change length, so you'll need to address that, too. The xfer in your '86 is probably a BW1345, with a 2.72:1 low range. the NP208 has a 2.61:1 ratio, and if I recall it's gear driven, versus the chain drive of the 1345. the 1345 is a good xfer case, but you might want to stick with the 208.
I've been looking at doing the same thing for my '86, but I wanted to stick with a fuel injected 460, and for me all I had to do was make sure I get the computer with the donor truck, and I was pretty much ready to go.
Krafty
Ontario Canada
all the parts you may need can be found here
http://broncograveyard.com/bronco/b-555
depending on how drastically different the lengths of the output of the trans and t case you may or may not need to change your shafts.
but Tip with the 208 the front and rear yokes can swap with each other if you ever want to do some custom shaft replacements
N
necessayrevil
as i was going through the computer at work i found that ford made two diffrient c6 4x4 trans, a short tail adapter and long adapter.does any one have any more info about this?
eholt80
