I have a set of five 38 x 12.5 15" super swampers . I am buying a new set of 15 x 10 36 bolt bead locks from a local off road shop but they have 39 x 15 super swampers on them but they are slightly used. I think one even has a plug in it but they have good tread. I can get the wheels for $900 by themselves. Im doing the sas and I will be running the dana 60 up front and dana 70 in rear. I havnt researched to know how much lift. Anyways question I need to know is which tire would you run based on the set up I have told you. This is on a 89' FS Bronco if that helps. Thanks for your help.
