picture of front brake line set up
kirk
Powell Missouri
Well guys, I hate to have to ask, but I have spent an hr our so searching the forums to find a picture or diagram that shows how the HARD brake line is routed behind the front wheels.
Let me start by telling you this:
I have my '75 Bronco (with standard brakes) stripped down to the frame. (I'm about a yr into a restoration) I have taken pictures of many areas KNOWING I will forget how things go back together.
So here I am.....ready to take the chassis to the paint shop to have the tub placed back on the frame. So I am in the hurried process of getting everything back together on the newly finished frame (springs, shocks, gas tank, etc) and also rebuilding the brakes while I'm there.
So with that, I removed the short HARD brake lines that runs into the wheel cylinders on each side)....and thought I had a picture how it is configured thru the little steel bracket, etc. But I do not have a photo......and that is what I am requesting......a pic or diagram of what it looks like behind the front wheel (either one) where that hard brake line is.
Thanks a bunch
Stand by for more questions
Kirk
It (bracket) "S" turns out & back toward the rear shock. The "clip" goes on & rubber from there to the cyl.
You're showing several EB's in your sig. Can't you look there...? :rolleyes:
If not...I'll try'n find my camera....... :unsure:
HTH
kirk
kirk
Powell Missouri
BB....Wish I could look at the other Bronco's as that would solve my memory problem. Those are Bronco's I have had in the past. Only have the '75 EB and F-250. It was an excellent point none-the-less. B)
A pic would really help. I don't know of any other Bronco's in my area (I live a bit "out of town")
I'm still searching the net for a pic.
Thanks BB
kirk
kirk
Powell Missouri
......and THAT'S why you are "Supreme Commander"
could I impose one more HUGE pic, most gracious Commander.....a shot of that short "S" hard line that attaches to the wheel cylinder....and how it goes thru it's bracket? I know I'm stretching your kindness.
Bow to me...!!! Bow to me...!!!
Seriously., "Alfred E. Newman" could be a "Supreme Comando" with enough posts..!! ;)
"that short "S" hard line that attaches to the wheel cylinder."
Sorry., I forgot 'bout that one. (even though I made my own).. :-"
It hooks up the same as the other end of the rubber flex hose. i.e. the hose slips thru the bracket hole...then a "horseshoe clip" holds it in place.
kirk
kirk
Powell Missouri
I'm BOWING, I'm BOWIMG!!!!
You are the best! That's exactly what I needed. It all makes sense now.
I really DO appreciate it, BB!!
Thanks so much
Good job Captain...!!!
Keep up the good work & you too, will be a "commando" one day.... :D /emoticons/[email protected] 2x" width="20" height="20" /> <):)
That, and $ will get you a cup-o-coffee..........
BTW.., where's some pics of your project/progress..? (share-time)
fred tyler
