overheating problem
muddybronco79
humble, tx
i have a 79 that just won't keep cool. i've even put dual electric fans on it to help cool it off on the trail, but nothing seems to work. any suggestions??
Yardape
Alberta
If your cooling system wont hold pressure it will overheat. First place to start is check for any leaks, get it pressure tested. I had an old ford pickup that kept overheating. Could find the problem then finally I yanked the motor to redo all the gaskets and also did the frost plugs, they were corroded beyond belief and one had pinholes in it. I replaced all the frost plugs and it never overheated again.
Bronc76
could also be a faulty thermostat or cap, or you may want to try flushing the system to see if anything is clogged. how's the antifreeze mixture?
muddybronco79
muddybronco79
humble, tx
all the plugs are good, and i fixed a leak on the radiator. i keep it at about a 50/50 mixture. the cap is brand new. i'm also thinking about taking the thermostat out. its just a trail truck only ran on the weekends.
92broncomann
Coolidge, Arizona
How new is that radiator??? you may need to get a new one or have it rotted out......
also how big is it?? my old man had a 78 with a 408 c6 and balls to the wall, ran atleast a 3 core radiator dual electric fans and a clutch fan with like 190 thermostat to keep it running cool.....
and a flush wouldnt hurt as stated by Bronc76
92BM
muddybronco79
muddybronco79
humble, tx
thanks for the input guys. all i did was spray the radiator completely clean and put my electric fans on the frontside of it instead of the back. doesn't go over 200 now
fred tyler
