OIL PAN
cj187
OK HOW THE **** DO I GET THE OIL PAN OUT I HAVE JACKED UP THE ENGEN TO THE FIRE WALL AND IT STELL WONT COME OUT HELP!!!!!!!!!!!!!!!!!!!!
LOL heres where everyone against body lifts will wish they had one . Without pulling the motr all the way out the only way I know to get it off it to jack it up as far as you can which you have if its hitting the firewall and then you must take the 2 bolts that hold the oil pump on and let it frop into the pan along with the pump will be the oil pump drive so DO NOT forget to put it back in . Then the pan should come forward and out . Good luck :D /emoticons/[email protected] 2x" width="20" height="20" />
