NP208 from an F150
Redneck86
First On Race Day
Colorado
Ok the guy i bought this T-case from didn work so he has another one that hes swapin me. I was wondering if the drive shaft from the F150 will go in my bronco, its an 81 short box. If it will good, if not do i have to swap out yokes?
And be sure the yoeks are the same style as your Bronco, because I doubt they will be the same fron an F-150. While they both use the same size u-joint, the width of the mounting holes for the flanges or yokes is different on the trucks than the Bronco in most cases. If you have your driveshafts out, test fit them to the t-case. You may be able to use the clamps on the yokes that are on the t-case on your ds. And be sure it doesn't have a slip-yoke rear output. That style is much longer and not desireable for the Bronco. JSM84
eholt80
