Newbie all around
darlingnikki
Hey! My name is Nikki and I just purchased an 88 Bronco. Its a 5.8L V8 4x4. I literally just got it today. I previously had an '07 Mustang but then life happened and I don't have it anymore :-( I knew all kinds of things about my Mustang and was a member of clubs and forums (where I learned most of it) so I thought the best thing to learn about my new Bronco would be to join a forum.
I will say it is quite a change! I will admit I don't know how to drive it, LOL! Anyone have any idea bout how many miles per tank? First thing I noticed was the gas gauge is broken. I put $40 in it and am nervous about running out until I can get it repaired after Dec 1st. So if anyone has any suggestions or ideas about that. :)
There's minor body damage and rust, looks like a previous cheap paint job (has drips/runs in it). Oh, and I noticed the PRND doesnt coordinate on the dash so I have to guess. Its been pretty ridiculous so far, LOL! The guy at the smog station was laughing at me and I said "I just bought it 15 min ago, I dunno what I'm doing!" He said "I can tell!" haha.
Well I hope I can get some great input from everyone and I look forward to learning lots here.
yo Nikki,
WELCOME
For Fuel Gauge;
Read through this stuff, then make a new post in the Technical Support, 80-96 Ford Bronco Tech Support Sectrion and state what the gauge reads; such as:
needle swings past E when turing Bronco on
needle swings all the way above the full mark
etc.
Testing in 87-88 Bronco & F Series; When the fuel gauge needle is below the 1/2 to 1/4 tank range the needle will swing all the way above the full mark on the fuel gauge; An erratic fuel gauge needle when the fuel tank is 1/2 to 1/4 full may be caused by excessive wear of the resistive film on the fuel pump sender assembly. The wear occurs during transporting of the vehicles via rail or truck over long distances. The fuel gauge will indicate correctly from a full tank to about 1/2 or 1/4 tank of fuel. When the fuel gauge needle is below the 1/2 to 1/4 tank range the needle will swing all the way above the full mark on the fuel gauge. To correct this, install a new fuel pump sender assembly. Refer to the appropriate 1988 Car/Light Truck Shop Manual, Section 24 for detailed service information. Refer to the following fuel pump sender application chart for the correct service part number. in Fuel Gauge Erratic TSB 88-18-03 87-88 Bronco & F Series 4.9L/5.0L (all PN E9VY-9275-A) & many others;Steve83 wrote, Pre-'87 fuel level senders are TOTALLY different from '87-up. Not only do they work over a different range; they work in the opposite direction
Source: by Ford via Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/724794
Fuel Pump Sender Application Chart
Model Year Application Engine Tank Size Service Part
1987-88 Mustang 2.3L./5.0L All E7ZZ-9275-A
1988 Lincoln Town Car 5.0L All E8TZ-9H307-G
1987-88 F-Series/Bronco 4.9L/5.0L All E9VY-9275-A
1987-88 Taurus/Sable 2.5L 16.0 E8DZ-9H307-F
1987-88 Taurus/Sable (W/ Tripminder) 2.5L 18.6 E8DZ-9H307-E
1987-88 Taurus/Sable (W/O Tripminder) 2.5L 18.6 E8DZ-9H307-A
1987-88 Taurus/Sable 3.0L 16.0 E8DZ-9H307-C
1987-88 Taurus/Sable (W/ Tripminder) 3.0L 18.6 E8DZ-9H307-D
1987-88 Taurus/Sable (W/O Tripminder) 3.0L 18.6 E8DZ-9H307-B
PART NUMBER PART NAME
E8DZ-9H307-A Fuel Pump Sender Assembly
E8DZ-9H307-B Fuel Pump Sender Assembly
E8DZ-9H307-C Fuel Pump Sender Assembly
E8DZ-9H307-D Fuel Pump Sender Assembly
E8DZ-9H307-E Fuel Pump Sender Assembly
E8DZ-9H307-F Fuel Pump Sender Assembly
E8TZ-9H307-G Fuel Pump Sender Assembly
E7ZZ-9275-A Fuel Pump Sender Assembly
E9VY-9275-A Fuel Pump Sender Assembly
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under Basic Warranty Coverage
OPERATION DESCRIPTION TIME
881803A F Series Aft Of Axle Tank 1.2 Hrs.
881803A F Series Midship Tank 0.9 Hr.
881803A F Series Both Tanks 2.0 Hrs.
881803A Bronco 1.2 Hrs.
881803A Lincoln Town Car 1.4 Hrs.
881803A Mustang 0.9 Hr.
881803A Taurus/Sable 1.0 Hr
Testing in 87-96; Fuel Gauge Moves from E to below E; "...Disconnect the connector at the fuel tank, ground the yellow with white tracer wire (make sure you have a good ground),turn the key on-if the gauge goes to empty, chances are, the fuel sender is the problem. If the gauge doesn't move, then recheck the grounding of the Y/W wire,if it is good then the problem is is forward of the sender (wiring/connectors/instrument cluster)..." Miesk5 Note, Steve83 wrote, Pre-'87 fuel level senders are TOTALLY different from '87-up. Not only do they work over a different range; they work in the opposite direction
Source: by 85bigbronco
for Fuel Gauge Sender Replacement w/out dropping Tank; see my Site Cut-out Panel Fabrication for Fuel Pump/Level Sender Replacement Section @ http://www.broncolinks.com/index.php?index=616
for such as;
Cut-out Panel Fabrication for Fuel Pump/Level Sender Replacement in an 83
Source: by the MAIN MOD & good pal here, Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums
http://broncozone.com/forums/index.php?showtopic=12329 a great source for quality body parts, repair panels (I used
For PRND
Need to ID what tranny is in there;
ASSuming (on my part)that the tranny type is original and a PO or shop did not swap the type for another model and left the gear indicator in-place, see;
AOD, C6 & E4OD Shift Indicator Patterns & Indicator pics; http://broncozone.com/topic/21070-shifting-problems/Source: by miesk5 at Ford Bronco Zone Forums
We can help you ID the tranny, transfer case types etc. later;
for now you can go through this;
Identification Based on VIN, Door Jamb Label, Build Sheet (Ford 999 Report), Paint Color Code, VECI Label, Transmission/Differential Pan & Gasket Sizes/Shapes, etc.; "... made a mistake 15 years ago by telling someone to use the Driver's side label to ID their Rear Differential (axle, pumpkin type, etc.); turned out that a previous owner had swapped a Dana 60 in place of the stock 8.8..."
Source: by miesk5 at Ford Bronco Zone Forums http://broncozone.com/topic/20082-help-me-need-to-know-specs-88-bronco-xlt-58l-351w/
For Body Parts, patch panels and other parts is our SPONSOR here,
Jeff's Bronco Graveyard
Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
GL!
kyleh01
