need the set up for a starter seloniod 86 bronco 2
mechel
someone took the wires off and now it wont start, tried to hook it up and it keeps shorting out anybody have the set up for the correct way the wires hook up???
Ford is not one to come up with too many ways to do something so I'd guess it is the same as a FSB. For older trucks the solinoid was on the inside of the fender. The arrangement there is Battery to one large post, starter to the other large post, and Key operated pick line to the small post, with any feeds to other circuits to the battery side. In newer ones, it is a relay with much smaller wire but basically the same, 12V to one main post, wire to solenoid on starter from other main post, and picked the same way as the other one was. the battery connection in this arrangement is to the solinoid mounted on the starter.
Put your truck information in your signature, it helps to get the right answer.
Coastersfwb
