need replacements?
bko4x4er
ok so i noticed the other day that the drivers side of my truck leans to one way. there is more clearence on the passenger side fender well in the front then in the drivers side. maybe the shocks are shot? or the spring is broken......should i go ahead and buy a leveling kit or just replace thye shocks or springs. i have 33s stock right now
i can hear thumping in my floorboard when i hit bumps
Check the body mount bushings under the floor of the cab, and under the radiator core support. Also check the suspension bushings on the back end of the radius arms where they bolt to the frame brackets. The original rubber mounts can dry rot, crack and fall out. This makes their mounts loose and sloppy in the steering, and the body mounts will gas. JSM84
swampthing
i agree with jsm84 check all the mounts and bushings if they are ok why not start with the cheapest and easiest tos ee if that fixes it meaning shocks? if that doesnt do it you can go from there and decide if you want leveling kit or new springs
