mystery part
dasferret
I have a 1984 Bronco II. It is no longer starting and is making a rather loud and harsh grinding noise everytime I try to start it, it doesnt even try to turn over. I located the part that is the source of the noise, and it looks like its a pretty straight foward switch out. I admit, when it comes to cars I'm lost beyond changing the oil and replacing a fan belt, so maybe you all can help me out. I'm trying to figure out the name of the part I need, it looks like a large tin can (about 8 in long) that only has connections on one side, and its located directly behind the battery. I figured it was the starter solenoid, but every place I've looked for one looks nothing like the one in my truck. any ideas?
From the description, I'd say it was the vacuum reservoir and I doubt that it is your problem. How about posting a picture of it just for verification.
Cube
Hey. I have a 1988 Ford Bronco II. But it sort of sounds like you chunked a couple of teeth on your flywheel. We have a Dodge where I work that does that. An easy way to check is (if it's a manual,) put it on a hill and with the transmission in gear and the clutch pressed in, let it roll a couple inches, pop the clutch, press the brake in and try to start it again. This will sort of force the engine to move a bit so the starter teeth can get a grip on the flywheel.
It works in the Dodge, anyway. Good luck.
StormChaser
I hope for your sake you are not having the same problem that I am fighting right now. The symptoms are the exact same. My problem has turned out to be a broken Drive Plate aka flywheel. In addition there is a spacer that goes between the drive plate and the crank shaft. I need to know the official name of that "spacer and where to get it.
kyleh01
