MY SPEEDOMETER AND ODOMETER DO NOT WORK
jimmyc6915
On my 1996 V8 5.0 Bronco my speedometer and odometer have stopped working. I thought that the only input they received info from was the rear ABS speed sensor but I replaced that and still no fix. Any suggestions?
If you pop the glove box out I think its called a PSOM its kinda gold in color thats the unit that the speed sensor feeds back to and then from there to the speedometer . Everything 92 and up has it . I used a 92 cab for my plow truck and have yet to make it work havent had much time to work on it though . I would look there and make sure it has power check all your fuses inside the cab and under the hood I dont remember right off which one it is but there is one that feeds it . Also check to make sure you dont have an oddball one that has a speed sensor in the T CASE it will be right where the speedometer cable would have been , Thats how I hooked up the one I have . :D /emoticons/[email protected] 2x" width="20" height="20" />
eholt80
