Mike,
Code 21 Engine Coolant Temperature Sensor (ECT)
Did you preheat the engine before you did the self test?
Check your coolent level also.
Then see...
http://fordfuelinjection.com/?p=28
CODE 23 Closed throttle TPS voltage higher or lower than expected.
I also suspect that you need to adjust your TPS.
I wrote a thread of how I did mine, and pasted the pertanent part below.
There are instructions in Haynes.
Just to round this out a little bit so that it is instructional.
The Haynes manual states that Adjsutment of the TPS is not necessary on the 4.9L
All other models must be adjusted. If you are working on a 1990 or earlier model connect the negative probe of a digital voltmeter to the terminal of the TP sensor with the black/white wire, and the positive probe to the dark green/light green wire. Note: You may have to insert stick pins into the back of the connector where the wires go in, and connect the probes to the pins. If you are working on a 1991 or later negative to grey/red and psotive to grey/white.
WIth the ignition key turned ON rotate the TPS until the output voltage is 1.0 volt. Tighten and recheck your voltage.
NB: Earlier in the chapter when trouble shooting is states that the output voltage should be between 0.5 and 1.0 volts.
Even though my TPS had round holes, there was enough play that an adjustment was possible.
As a side not on my '90 the TPS I pulled off, and the new one I put on had different color wires.
Black was Sig Rtn
Orange was TP Sig
Green was V reference
With the throttle closed should get 1.0 volts between the orange and black and
with the throttle fully open 5 volts.
You should also get 5 volts From the computer to the TPS by checking Vref (Green) and ground SIg Rtn Black.
You will need a digital voltmeter.
I needed to use a third hand the first time I did it, later I used some push pins, and aligator clamps. I stuck the pins through the insulation of the wires, and the aligator clamps to connect them to my voltmeter leads. A little sloppy but it worked
/emoticons/
[email protected] 2x" width="20" height="20" />
Note:
in my edition of the book on page 4-22 it states to check it, it should be between 0.50 volts and 1.0 volts at idle. Later on page 4-23 it states when replacing it "rotate the sensor until the output voltage is 1.0 volt."
Well I couldn't get it exactly at 1.0 volt! A little above or below, but NOT just 1.0
So I opted to set it between 0.5 and 1.0 as close to 1.0 as possible, I think I am at .96
I think that I found the diagrams on this page helpful
http://fordfuelinjection.com/?p=30
BTW: I used a little high temp silicone sealant with my throttle body gasket when I put the throttle body back on to help insure no vacuum leaks occured there.
Overall... make sure all of your electrical contacts to your sensors and actuators are clean and tight. I used a
little dielectric grease on them to add a little future protection.
Regarding
CODE 44... THERMATOR AIR INJECTOR SYSTEM RIGHT SIDE I don't know about that
