Nickyhatch
on a stock bronco stock ignition can you install a 6al hastle free with out worrying about anything thanks in advanced
I've had mine so long I don't remember. I also have the MDS Blaster II coil and the combination makes a much hotter spark than the Ford Duraspark II which should give more power because of a much better spark. One thing I do know is that I don't have the problems I had with the Ford ignition.Is there any signifigant power increases im about to put an msd system in my truck in a couple days or so. Thank god i can keep the same distributor once i get a 460 cause they arent cheap.
