motor swap
scrub
Ponoka, AB
going to swap to a 351w in my 76, will the original c-4 & dana 20 tcase handle the extra torque? Would it be better to stick with a 302? Any suggestions on which is the best motor swap for ease of install & power gains? Thx.
"will the original c-4 & dana 20 tcase handle the extra torque"
Depends on how you use it...The D-20 is fine. If you are rock'n & mudd'n ...a C-6 might be in order.
"Would it be better to stick with a 302?"
IMHO.., yes....for a bunch of reasons.
S
scrub
Ponoka, AB
how hard is it to convert to a c-6? what kind of 302 would be the best to switch to? Working on a tight budget so looking to buy a used motor for now. I assume a mustang 5.0HO would be a pretty good motor. What year is the best to harvest from? If EFI can the whole setup be swapped?
Hay scrub..,
None of what you're suggesting is cheap...Wadd-up with your pres. motor..? :huh:
"If EFI can the whole setup be swapped?"
Yes it can.
S
scrub
Ponoka, AB
Original motor still, burns lots of oil, runs rough in N & then stalls all the time when put into gear, have to put it in 4L just to get it to move, all kinds of ticking coming from the heads, would assume they are toast. The motor has never been strong, lacked power in 2 & 4H. Always used 4L for wheelin. I would think a good 302 should be able to turn 33's.
"...I would think a good 302 should be able to turn 33's."
You bet..! A fresh 302 will suprise you to no end...(especially compared to the condition of your present mill.)
I was recommending a stock 302.
The swap in the post below is out of my realm of expertise....
S
scrub
Ponoka, AB
Did some research on site & came up with 88-93 car motor for a good EFI 5.0, this is supposed to have the mass air sensor which is better, anything besides a Mustang that would be a good donor vehicle? Is my info correct?
Bronc76
Hay scrub..,None of what you're suggesting is cheap...Wadd-up with your pres. motor..? :huh:
Yes it can.
Scrubs
Rebuild your present motor if you can or save it until you can. If you put in a used motor, you dont know how long it will last assuming if it hasnt been gone through. I bought a used 302 for my F-100 and lost a main bearing 2 weeks later. I have to agree with bullybob, a fresh 302 will spin 33's. hope the info helps.
