More Horse's
AleWagon
I'm sure if I look hard enough I can find what I'm looking for...not enough time!!
'96 XLT 351W 3" body and 6" sup on 38"...I need gears and more power...HELP!!!
Sorry, don't have enough time to cover the subjects :-" except to say, "Got Money?" :rolleyes:
Ale. I think you have the answer to your question: new gears, like a 4.88:1 ratio. I just bought a set of 4.56:1 gears for my 84 Bronco on 35's from 4WheelParts. They are Genuine brand with a lifetime warranty. For both axles and the install kits was like $460, and a new carrier for the front is another $60 on ebay. Think also about traction aides if you plan to do much offroading. Since I have a Ford 9" rear axle, I bought a $30 mini-spool for it. And since I am offroad-only, thinking of getting a full spool for the front axle ($90). A Detroit locker or Trac-Loc may be better depending on your type of driving and how much street use you have. JSM84
A
AleWagon
JustShootMe Thanks I think I will go 4.88 on the gears I do have some street driving to do...so Trac-lockers it is!!!
Truck
I could probably set you up with a 460, if that's your thing-would most likely require a lot of luv, but they have cheap blocks where I'm from.
