Heres what I did so far, I cleaned the connections ALL of them. This did help in the charging process it seemed. When I first start the vehicle the gauge reads almost 3/4 but as i drive it steadily drops and once i run some stuff its below half. if im running nothing it stays at half or a little above. once the heat/headlights/wipers/blinkers are on it drops more with each thing on. I'm looking into one of those high output alternator just because its good to have, i have 6 aux lights with 3 switches 4 on top 2 behind the grill and if i even use one set (2 lights) my battery is workin real hard lol. when i have my heat/wipers/lights on my battery is struggling real hard to stay below half except when its cold out so its a weird scenario, Im guessing the alt is just NOT strong enough for the vehicle. if it sits for a while the battery somehow regains power and is real strong but if i start the car then shut it off, then start the car a few times over, itll die. so maybe its the battery not holding proper charge...I will take the positive terminal off and try that technique, and im assuming if it sill runs then the alt is good. then should i assume its the battery? I apologize for the double post also, i couldnt find my original post..im not used to this forum yet, is there a way to search your own threads? thanks again guys
What gauge are you talking about 3/4, 1/2. I get the feeling you are talking about a charge gauge not a volt meter. A volt meter is calibrated with numbers on it like 8, 10, 12, 14. A charge gauge indicates if the battery is being charged or discharged. A center needle is no charge, to the right of center is charging, and to the left is discharging. All of them are normal things to expect. When you are turning over the engine to start the truck you can expect to the left of center or 1/2. After the start you should see the gauge go to the right of center indicating the alternator is charging the battery, it should eventually settle down to center or 1/2. If you add a load that the alternator is not capable of handling, you could expect it to go to the left of center or the battery is discharging.
The function of the battery in a properly designed system is to only start the truck. Once the engine is running the alternator should take over and recharge the battery as well as supply the demand of lights, radio, ignition, etc. The battery should only have to make up for short comings of the alternator on a momentary basis. If the gauge stays below the no charge line, (center), for any length of time then the alternator is either does not have enough capacity because it is weak or is too small for the job. A system with heavy lighting like you describe should have a high output alternator, probably 130 to 200 amp capacity.
If that is the case then you should consider doing a 3G alternator upgrade.
You should b e able to find your posts by viewing your profile. In the center of the page is a list of your posts. Also, just remember what forum you posted in and look at the list to find your user ID as the person who started the thread.
