Make Trail Capable
Road Kill
Wall, New Jersey
i Drive A 1990 Bronco Fullsize Striped down inside aeroturbine exhaust and some goodyear mtrs but everything else is stock i want to lift it but i am not sure the best combination of lift hieght tire size and should i upgrade axels or is that not necessary if so what are best and is fender triming necessary to make the truck realy capable thanks for all the help
CraZAg
San Angelo, TX
You've got to know what kind of off-roading you want to do. If you are wanting to get fairly crazy, you'll need a 4" to 6" lift. You can get by without fender trimming as long as you don't try to go too big with the tires. 35X1250s will fit nicely with a 6" lift without rubbing. You'll only need to put axles on if you are going to the extreme on really tough trails. You might want to experiment a little before you put axles on to see if that's the route you want to go. Hope this helps. Look around the forum for more info on tire and lift combinations.
eholt80
