loose steering
tripleh87
Benton Harbor, MI.
not sure if this has been answered yet or not. i've been able to turn my steering wheel about 3-4 inches before my tires start turning for a couple of months now. i took it and got a front end alignment and they said that my steering coupler was bad. i told a guy at autozone was was goin on and he also said it was the steering coupler. he said that it was by the firewall on the inside. i have no idea where exactly the damn thing is. well, tonight i was on my way to my mom's house and i could turn my steering wheel almost 3/4 of a turn before the tires started turning then something felt like it locked back in place and i barely turned the steering wheel and the tires turned. i decided to take my truck back home and get my wife's. i moved hers and parked mine in the spot where hers was parked and i tried to straighten my truck out a little bit and my steering wheel just spun and the tires didn't turn or anything. what broke and where the **** is the steering coupler? does anyone have a picture of the break down of the steering column? thanks for the help.
jeremiah
Ziggy
Riverside, Ca
Most steering couplers are at the end of the steering shaft at the gear box. They look like two big washers with a rubbber disc in between them. You will have to loosen the clamp on the the gear box side and I believe bolts hold it to the steering shaft in order to remove it. I would remove the old one first and then take it to the parts store to match it up with the new one as there are differant sizes. New one should run about $10.00-$25.00.
T
tripleh87
Benton Harbor, MI.
i fixed my steering this morning. it wasn't the steering coupler, the damn set ***** on my borgeson steering shaft at the gear box wasn't tightened all the way. i tightened it back down and now i only have about an inch of slop in my steering. much better.
DragonDave
The OC SoCal
18512[/snapback]
Now adjust your steering gear box & get it even better! :) /emoticons/[email protected] 2x" width="20" height="20" />
Shadow_D
Schenectady, NY
What is the correct way to tell if the box it adjusted too tight? I know I risk the chance of burning out the pump if I over tighten the box.
mcfly69505
Renton Washington
Yea, Im basically having the same problem, but its been the same way since I bought it and Ive had it for about 2 years now. Im thinking that if something was going to break on it, it should have broken already so I think its probably just an adjustment on mine.
~Mcfly~
Joey D
18596[/snapback]
How do you adjust that? Have pictures how to adjust? Thank you!!!
Having same problem. 96 Bronco fullsize
eholt80
