little help with headman headers
dsgb9840
atlanta ga
so i got some headman headers off bronco graveyard. well they are long tube headers and they come way farther back and end about 6" after the trans starts..well on the drivers side is the front drive shaft and then farther back the transfer case completely blocks any the exhaust could go through. and the only way to get it to the passenger would be to cross it under the trans. any one figure out (and have pics) of a similar system with long tube headers?
dsgb9840
dsgb9840
atlanta ga
does no one have long tube header on ur broncos?? or a true duel exhaust??
BB33's
Rancho Cucamonga CA
Why not just cross it under the Trans? After that just run the pipes parallel to each other until you hit the muffler or cats depending on your plans.
Redneck86
First On Race Day
Colorado
Yea i a set of Hokker full length headers on my bronco. You gotta unbolt the front drive shaft at the diff to get them in. Then i had dual Flows run from that. Ill see if i can take a picture of it sometime.
black beauty
tennessee
yes i have the same headres you have as well as a true dual exhaust. any questions you have send me a pm and ill tell as you as much as you need to know about it cause i ran into the same problem
dsgb9840
dsgb9840
atlanta ga
love some pics...here's the difference i have '94 WITH 351w AND e4od TRANS....witch is a lot bigger...and i've seen them on a 302 with c6 trans and the headers i have don't stop till behind trans. pic for reference.
P.S. if u run exhaust under trans your just asking to pinch it shut
88BroncoBlack
Chicago Suburbs
i have hedmans, didnt have to unbolt anything to get them in and i crossed it under the pan and followed the normal route to the back then split to go out each side, tottal true duals
joshwht
Western Massachusetts
I have an 82 with a 351W and a C-6 with true dual exhaust and Hedman headers. The guy who welded it up for me went over the transfer case. It came out really nice. The pipe is pretty close to the driveshaft, but it has never rubbed.
kyleh01
