yo!
Yes as shift cited, you can damage the moulding, but it is aval in most yards in F series or broncos
Here are 2 moulding removal tool pics & info;
Windshield Moulding Removal in an 89 by J.R.
http://www.supermotors.net/getfile/282108/...size/89-154.jpg by Steve..."...This is the tool I like....the sharp points help.
Slip the tool under the trim and slide until you hit the clip. Rock the tool pulling the clip away from the body. Push at the bottom of the trim and the top should pop up..." Nothing clips to the glass; they all go on rivet studs in the body. There are ~16 of the upper clips & ~7 of the lower ones, but they're all reuseable. All '80-96 trucks use the same clips & moulding, and this tool works for both clips. See the NEXT few pics for more info.
Windshield Moulding Removal & Tool Instructions & pics in 80-96; "...Nothing clips to the glass; they all go on rivet studs in the body. There are ~16 of the upper clips & ~7 of the lower ones, but they're all reuseable. All 80-96 trucks use the same clips & moulding, and this tool works for both clips. See the NEXT few pics for more info. The tool slips under the windshield trim. Slide it to hook the clips, beginning at a joint near a corner; Hold the tool at an angle so one point goes behind the clip. Turn the tool to pry the clip slightly toward the center of the w/s, then lift the trim just enough to disengage it from the clip. The lower trim clips are different, but they're released the same way..."
New Clips are in high demand but avail at a few sources; local windshield repair, NAPA, etc.;, & Ford dealers
and yards...
E1DZ-6629100-A MLDG CLIP 4 pieces per bag
Windshield Belt Molding Clip E1DZ-6629100-A 2.00 Each
http://www.parts123.com/index/parts123-index2210.htm
every windshield needs 9 of these at the bottom
WINDSHIELD MOLDING CLIP KITThese are the clips that hold on the metal trim molding around the windshield. There is enough clips in this kit to install the moldings around 1 windshield.
APPLICATIONS:
80-96 FORD F150 PICKUP
80-98 FORD F250, F350 PICKUP
80-96 FORD FULL-SIZE BRONCO
Glass shops use a smoke machine or smoke candles (Diesel service shops have something like this for DIY; tell em why you need them and they'll give you enuf; may need to use plastic sheeting to contain smoke close to windshield on inside (cab).. they use Butyl to re-seal the ws.
Check under carpet or mat to ensure water is not damaging the PCM... in reply mode, I can's see your year... so am trying to recall..later year? Look for water trails on connector, PCM, etc.
