Leaking Coolant
bvteachey
NC
I parked my Bronco the other day, stepped out and heard a hissing noise. It was coolant spraying out from under the motor. I pulled the lower radiator hose off and it didnt seem to be busted but for good measure bought a new one. I havent had a chance to put it back on yet, but i know that the spray appeared to be coming from behind the water pump area... now im definately second guessing the hose being bad. Any one got any ideas or things to look for to figure it out? Thanks
muddrivermike
Texas Arp
Sounds like a water pump or gaskets.Obviously you have to track were its coming from.Refill it and run it and see where it starts leaking from. ^_^ /emoticons/[email protected] 2x" width="20" height="20" />
Sandoval_broncosauria
